I recall looking into the MTRs a few years back during one of those quests to identify all the locations and I suspect assigned training establishments, but I can't find any notes I made at the time!
West Freugh was originally an Armament Training Station but a war broke out, changing plans. The MTR was certainly in place by December 1940 (Luftwaffe AP) and probably built in 1939. Given the short-ish distance to Castle Kennedy it would make sense for them to use it, howver this is not proof.
Bishops Court too had a brief AGS function but mid -war but I have found no evidence of a MTR associated with that airfield. Perhaps the MTR element of the AGS couse was deleted and relied on firing on the flag instead.
I wonder if there was a limited time window when they were used? I know some were in use by 1940 but when was the last one built? Snettisham was probably one of the last. However they were still being built in 1941 as Wigtown's wasn't even started in February 1941. Possibly Bishops Court was being planned but things changed before work started. Some things didn't get done very quickly. Mind you I think one, possibly Silloth, was being looked at to be re-orientated at the end of the war.
I also recall that there weren't many spare sets of equipment to build them. Holbeach ranges was due to get one but it was put on hold and I think bits were stored at Sutton Bridge. I think these went to Snettisham in the end.
A lot of unknowns! Possibly the AGS ORBs would shed some light. Shame they aren't online.
Chivenor was to have had a 200 yard MTR but it appears never to have been completed or, perhaps, completed but never commissioned.
Here's a LIDAR image of the area. The familiar 'lozenge' shape of the MTR earth walls can be seen in the centre of this screenshot directly above that odd windblown dune which is a feature of the terrain:
This area is confusing to due references to various ranges in the area as Chivenor's ranges. This MTR was part completed for the RAF but work stopped as the role of Chivenor changed. It was to be taken up by the USAAF but I don't know if it was completed or used by them. The location is odd for the USAAF but then again they did use Mousehole for gunnery training. The sands was host to another RAF range, Saunton Sands, which was an air to ground ranges. If US Army documents relating to the Woolacombe Assualt Training Area are correct the two RAF ranges were adjacent. In July 1943, when the area was being reviewed for assault training the Air Ministry had decided that the MTR could be replaced by a standard free gunnery trainer. There was no mention of potential USAAF use so perhaps this was after the area was for assault training?
The other RAF range, Saunton Sands was being used by Coastal Command and they were forced to look for a suitable alternative. This I suspect was Northam Burrows but that is another unresolved story.
Interestingly in 1942 the Army had a range, type unknown, on Braunton Burrows but it was marked as not in use.
Shows that the target was only just visible above the earth bank crossing from right to left although I suspect that the direction of travel was reversed randomly to prevent circuit fixation.
EDIT: Zooming the image shows what is, probably, the Target Trolley building which was reinforced concrete protected by earth banking and must have routinely been hit.
"New to Collections Online: the complete B and BU Series of British official photographs. These 23,000 cover the British Army, and Allied Operations in North-West Europe from D-Day on 6 June 1944 to December 1946 including aspects of the Allied occupation of Germany"
