200 yard Moving Target Ranges
07 Jan 2013 11:01 #221 by PETERTHEEATER
Replied by PETERTHEEATER on topic 200 yard Moving Target Ranges
According to PNKs research, there were two ranges at Hell's Mouth an A and a B. The A had an off shore practice bombing target and an on-shore Air to Ground gunnery range and the B had an off shore live bombing target. Since one of two QS was usually adjacent to the Directional Arrow the second QS would (in my opinion) been located on Mygydd Cilan peninsula around here:
wtp2.appspot.com/wheresthepath.htm?lat=5...2363&gz=15&oz=8>=1
For the A range (PB) the building seen here:
maps.google.co.uk/?ll=52.821817,-4.61802...bp=12,180.1,,0,11.63
.......is in a good location. The Street View image just seen through a gap in the trees resembles a tractor cab but, for my money, it is a QS.
But, where was the PB target? Knowing that would enable the location of the second QS but it has probably succumbed to coastal erosion.
07 Jan 2013 13:56 - 01 Jul 2017 15:18 #222 by Peter Kirk
This is the Hells Mouth range (Also lumped in with Penrhos ranges on some charts). I don't appear to have a full chart or map of the ranges here, despite thinking I did. Most charts only show the overall danger area which included air to air firing tow lines. The quadrant by the arrow would have served both the live range and a practice range to the SE. Strangely the aerial photo of the area from 1946, in Ivor Jones' book, only shows a live arrow so possibly the practice range didn't have an arrow at that quadrant.
A likely location, in the area PTE pointed out is below but I fear my mind is playing tricks on me as I see arrows everywhere!
If you plot the points from both the live arrow area (the red one) and my phantom arrow the 1000yds radius for a standard practice range tucks in nicely, just touching the beach.
07 Jan 2013 16:12 - 01 Jul 2017 15:17 #223 by Peter Kirk
I wasn't dreaming after all!
07 Jan 2013 17:58 - 24 Dec 2017 19:27 #224 by carnaby
Replied by carnaby on topic 200 yard Moving Target Ranges
I'm getting a bit confused about these two arrows. Guess the Hells Mouth entries need moving to an appropriate thread.
The RSP shows one of them. I found this one a decade ago when it was beginning to fall onto the beach. Location
'A' seems to be something to do with the landing strip boundaries.
What are 'B' and 'C' ?
07 Jan 2013 18:21 #225 by ianbache
Replied by ianbache on topic 200 yard Moving Target Ranges
Hi Carnaby
The pic i took, #216 off the arrow is from the above location it wont be long before it disappears for good judging on the erosion of the dunes into the see,
Regards Ian
07 Jan 2013 19:40 - 11 Sep 2017 13:05 #226 by ianbache
The Observation hut situated at Rhiw , Taken by Eric Jones, on the Geograph site
SH 23035 28162
The other hut is situated at Punt Gwynedd SH 27311 27266
Hope thats of any use to you
Regards Ian
07 Jan 2013 20:12 - 01 Jul 2017 15:16 #227 by Peter Kirk
I will split out the Hell Mouth Bombing Range in the next day or so.
RE: Carnaby's "B" & "C" - "B" was the officers control post and "C" was the W/T room and searchlight platform. Would that be a typical symbol for W/T? . Missing from the arrow is the little triangle at its base to signify "LIVE" targets.
Ian, Hopefully the attached map will make things a little clearer. The target locations may be a bit off but certainly within the right area (+/- 25yds). The building in the picture above does not fit in with the range as it is too far away. It may be a Coastal Observation or Lookout point. The Punt Gwynedd structure is the main markers shelter and is to do with the air to ground range. Once the Hell Mouth Range stuff has been split out I will try to draw up the layout of the air to ground part.
07 Jan 2013 20:30 #228 by ianbache
Many thanks PNK, i understand it abit more now from the above map, i go here quite often it would be nice to see the layout for the range, if you need any images taken please give me a shout
Regards Ian
07 Jan 2013 20:37 #229 by Peter Kirk
NOTE: The Hells Mouth Bombing Range posts have been copied or moved to their own thread here /community/showthread.php?9952-Hells-Mouth-Bombing-and-Gunnery-Ranges&p=118396#post118396
I have left the deleted visible in case I messed up the moving!
07 Apr 2013 00:31 #230 by P Bellamy
Replied by P Bellamy on topic 200 yard Moving Target Ranges
Some very interesting new info has come to light this weekend, primarily on the Snettisham range.
(Source: USAF via 1AD HQ Hist. Soc.)
Apologies for the wonkiness, I had to stitch it together from six frames of poor-quality microfilm.
However, amongst other things it would seem to confirm Theddlethorpe was the first of the type.
Time to create page: 0.078 seconds
