- Thank you received: 2
The photos are all earlier on in the thread.
BDU33 DB's
Smoke & Flash's
20mm, 30mm, .303, 50 cal, 7.62
We found a couple of tank shells aswell
You name it it was there
There were some other blue fibre glass bombs like smoke & flash but a lot longer cant remember what they were now i'm going back about 10 years.
So Beerie
You know what your handling , what does a yellow band around a tail section denote ??
The yellow band means theyre inert isnt it.
If I remember it's a front weighed practice bomb. That when the nose strikes ground it pushes the firing pin into a shotgun size cartridge that emits smoke through the hollow pipe to the tail.
No high explosive at all. Nothing more than a striker activated smoke grenade.
Same for the plaggys. Tho they used the force of hitting the ground to cause the cartridge to strike the fixed pin. Again. Shotgun sized smoke cartridge. Noooo HE
Answer don't touch . Yellow Band denotes HE Which I think you know is HIGH EXPLOSIVE.
BD33 / BDU33 We classed these as live , until demolition !! Cowden was also experimental site there is very dodgy material on there . You have had a lucky escape !!
I don't want to come across as patronising Beerie .
(Its ok norwichpaul i'm learning here.)
Not at all BDU, what sort of experimental stuff was dropped there then? Never saw anything out of the ordinary. I think everything we saw had red bands around it and all painted blue denoting practice? (smoke & flash)
We use cookies to improve our website and your experience when using it. Cookies used for the essential operation of this site have already been set. By continuing to use this site you are agreeing to this. To find out more about the cookies we use and how to delete them, see our privacy policy. | |
| Hide message | |
