Finds and UXBs!
06 May 2013 11:48 #241 by John Anderson
Replied by John Anderson on topic Finds and UXBs!
Thanks Peter that is the one, found in the valley bottom east of the markers shelter. Now for the RP fuse?
The two brass components may be part of a fuze assembly. The RH component appears to fit into the bore of the stepped brass component? RAF and RN used either 25 pound solid shot head or 60 pound SAP Head with rear internal fuzing. Those components imply a direct acting nose fuze typically used on ground to air (anti-aircraft) rockets such as Z Batteries.
Treligga finds. Oerlikon 20mm case on the left compared to a Hispano version on the right. RP head? The brass fuse? would fit exactly into the RP head.
20 May 2013 14:25 #242 by pumpkinv12
Replied by pumpkinv12 on topic Finds and UXBs!
I found this whilst wandering around a bomb dump a while ago.
It measures 3" across and is threaded on the back.
I think it's some some of blanking plate ?
Steve :)
20 May 2013 14:54 #243 by PETERTHEEATER
Replied by PETERTHEEATER on topic Finds and UXBs!
Yes, it's a blanking plug for a bomb fuze/pistol pocket.
20 May 2013 15:30 #244 by pumpkinv12
Excellent thanks.
Steve :)
20 May 2013 15:33 #245 by pumpkinv12
20 May 2013 23:53 #246 by Karl H
Replied by Karl H on topic Finds and UXBs!
That is the top of a small ammo can that could be attached to the side of a 50 caliber gun. Cool find!
Here is mine:
21 May 2013 01:51 #247 by Peter
Replied by Peter on topic Finds and UXBs!
Interesting finds...
Cheers,
21 May 2013 07:02 #248 by pumpkinv12
Oh right, it came from a field were allegedly a B24 crashed just after takeoff.
Steve :)
24 Jun 2013 21:07 #249 by pumpkinv12
Whilst at North Creake airfield today I found this.
It is made of brass and is about 4" long and has N28 MK111 S M P 1/41 written on it.
Over to you guys.
Stephen :)
24 Jun 2013 21:09 #250 by P Bellamy
Replied by P Bellamy on topic Finds and UXBs!
RAF No.28 bomb tail pistol.
The smaller knurled end should unscrew to reveal the firing pin and it's retaining spring.
Time to create page: 0.068 seconds
