Unknown Propellor
24 Nov 2015 18:58 #1 by REF
Unknown Propellor was created by REF
Hi all
These photos were taken by my Uncle of a propellor that has been recovered on the Greek island of Symi. Does anyone know what it could be from?
24 Nov 2015 19:08 #2 by ianbache
Replied by ianbache on topic Unknown Propellor
Hi Richard,
Could it be possibly from a Beaufighter
Regards Ian
24 Nov 2015 19:14 #3 by REF
Replied by REF on topic Unknown Propellor
My first thought was Blenheim but it could be a Beaufighter.
25 Nov 2015 08:17 #4 by PETERTHEEATER
Replied by PETERTHEEATER on topic Unknown Propellor
Might be either. Versions of both Bleheim and Beaufighter had 3 blade variable pitch props. The gear arrangement on the subject prop was to drive the pitch mechanism for constant speed.
25 Nov 2015 20:13 #5 by Bigbear
Replied by Bigbear on topic Unknown Propellor
The blades seem to be bent the wrong way. If the aircraft was travelling forward wouldn't they be bent towards the gears? Is this because of an undercarriage collapse perhaps?
26 Nov 2015 07:15 #6 by PETERTHEEATER
I will stand corrected but the pitch gears would have been covered by the propeller spinner.
26 Nov 2015 09:44 #7 by Iain Taylor
Replied by Iain Taylor on topic Unknown Propellor
I don't know much about the gubbins but the gears would be on the engine side of the paddle things.
As the blenheim over here has a habit of crashing there will likely be photos or videos of it's various rebuilds. You could try comparison to that Rich. I don't have any photos here but fairly sure the spinner on it is quite thin rather than conical. Fairly sure the beaufighter was similar.
Quick search - hopefully this link works
www.warbirdsonline.com.au/warbirds/wp-co...Blenheim-UK-2014.jpg
Later beaufighters seem to have had larger spinners than early ones from my quick search for photos online.
26 Nov 2015 10:35 #8 by John Anderson
Replied by John Anderson on topic Unknown Propellor
Just looking at "Beaufighter at War" by Chris Bowyer, which has several photos taken after belly landings. The earlier Merlin and Hercules powered versions seem to have the larger spinners, which could cover the prop. pitch gearing.
26 Nov 2015 16:38 #9 by flatusmaximus
Replied by flatusmaximus on topic Unknown Propellor
I thought that the blades were bent the 'wrong way' too. I just can't imagine any scenario such as collapsed undercarriage, forced landing, ground loop, etc., which would cause this.....
26 Nov 2015 17:51 #10 by Peter Kirk
Replied by Peter Kirk on topic Unknown Propellor
That's a hefty bit of kit to have forward of the propeller, even if it was covered! I did think of contra-rotating props but the un-propped gears looked wrong. Any idea what the gears do as they seem to reverse rotation with a slight reduction or increase, depending on direction?
Time to create page: 0.057 seconds
