I was checking the Brunton area on NLS a few minutes ago, not that I'm particularly interested in the place, just intrigued why some airfields are depicted, but most are not, when I came across this loop of railway lines in the middle of nowhere. Poss a range of some sort?
The railway was suspected as being a mineral railway but does not appear on pre-war maps, although thae date gaps for this part of the world could easily have missed them. The observation tower is interesting as it doesn't appear on most maps post war. It could have been range control for the tanks or maybe a lookout of some sort.
You can park your car at Ross and walk out onto the links . I've been that far but no further yet ! There are two surviving quadrant towers at Cheswick and in the booklet 'Exploring the Historic Buildings of the Northumberland Coast' , ISBN 9781 873402 22 2 , 2006 , there is mention of some range building foundations near Ross and I wonder if this is the 'Observation Tower' marked on the map above ? There are also lots of concrete hardstandings in this area which are clearly visible on GE .
I think the observation tower is also there on the 1947 photo, probably to control the whole area. The tower would need to be fairly high to see over the dunes.
So that is where Stobs is/was. I had a reference to a range their used by aircraft but failed to locate it. Yes that is a tank MTR. Once I found out what they were I seem to spot them everywhere!
