Can anyone identify the attached fixture -
01 Feb 2011 21:56 #1 by hydealfred
Can anyone identify the attached fixture - was created by hydealfred
This item is located externally on a fusing shed at an airfield in Hampshire. It appears that the ball like fitting at one time swivelled. What is it and its purpose ? Below it on the wall there are what appears to be brackets that terminate at ground level.
02 Feb 2011 07:59 #2 by PETERTHEEATER
Replied by PETERTHEEATER on topic Can anyone identify the attached fixture -
What type of building is it? Nissen or TB? Is the fitting on an end wall adjacent to the door(S)
02 Feb 2011 08:24 #3 by DG1
Home made by farmer for some reason.
Sawn off arm, from tractor three point linkage bolted to a eye bolt for hanging a gate on.
Live Your Dream Ask Me How.
www.bazjasp.co.uk
02 Feb 2011 13:15 #4 by hydealfred
Replied by hydealfred on topic Can anyone identify the attached fixture -
It is on a 1929 brick built fusing shed. It is located next to the front entrance door. The building had the later addition of a blast wall built around the entire structure. This fitting is on the internal original structure.
02 Feb 2011 19:04 #5 by 92fis
Replied by 92fis on topic Can anyone identify the attached fixture -
I'd agree with that. The piece that went into the brick work may have been original but the bit with the ball is certainly part of the three point linkage off an early tractor.
02 Feb 2011 22:01 #6 by hydealfred
Hmmm not quite sure what the purpose of that would be then ?
03 Feb 2011 05:17 #7 by PETERTHEEATER
It certainly looks like a trackrod end with a spherical bearing and I assume that it is an agricultural addition.
Are you sure about the age of the building?
03 Feb 2011 21:20 #8 by hydealfred
Yes there is a 1929 date stone in the wall.
04 Feb 2011 04:27 #9 by PETERTHEEATER
Can't be more positive than that. Now I know where it is! This building may be unique, I don't know of another. Is there a preservation order on it?
Are there indications that the later external concrete surround wall was backed with earth traverses? This could indicate a change of function and give a clue to your mystery object. Any idea what the roof material was?
04 Feb 2011 11:56 #10 by Alex Brown
Replied by Alex Brown on topic Can anyone identify the attached fixture -
I know they were a bit keen on putting the date on things in the 20s, but that seems rather OTT for a humble fusing shed!
