Unknown Aircraft Pod
15 Nov 2016 17:10 - 15 Nov 2016 17:47 #1 by Paul Francis
Unknown Aircraft Pod was created by Paul Francis
Can anyone identify this please. I think the aircraft is an Avro Ashton and it was taken at Hatfield. Edit the aircraft might also be a Short Sperin but I think its more likely to be the Ashton and I am thinking it might be a camera pod,
15 Nov 2016 18:22 #2 by Peter Kirk
Replied by Peter Kirk on topic Unknown Aircraft Pod
It looks to be pointing to the fuselage, assuming the photo hasn't been doctored. I wonder it is pointing to an engine on test?
15 Nov 2016 18:42 #3 by Dietmar Morley
Replied by Dietmar Morley on topic Unknown Aircraft Pod
I dont think it's an Ashton as all their tail numbers began with WB with one starting WE. That looks like a port wing (assuming image not mirrored) so the markings you can see in the picture would be the top part of those letters.
For the record:
Ashton 1
WB490
Ashton 2
WB491
Ashton 3
WB492
WB493
WE670
Ashton 4
WB494
15 Nov 2016 18:47 #4 by Dietmar Morley
Which means it's unlikely to be a Sperrin:
VX158
VX161
15 Nov 2016 19:38 - 15 Nov 2016 19:38 #5 by Paul Francis
Replied by Paul Francis on topic Unknown Aircraft Pod
A good bit of detective work so far.
15 Nov 2016 19:42 #6 by Paul Francis
A bit of dihedral might help?
15 Nov 2016 20:01 #7 by ianbache
Replied by ianbache on topic Unknown Aircraft Pod
Could it possibly be a sampling pod modified from drop tanks, it does look as if the 2 nozzles are pointing into the airflow ?
Regards Ian
15 Nov 2016 20:34 #8 by WJT
Replied by WJT on topic Unknown Aircraft Pod
Canberra.
15 Nov 2016 20:45 #9 by Dietmar Morley
Canberra.
Good call! The wing tip light configuration matches.
15 Nov 2016 20:53 #10 by WJT
Need to do some digging, but perhaps the trials aircraft for the AS30 missile or perhaps watching stores carriage and release from the inboard pylon.
