Flying Through Fire - Geoffrey Williams
08 Sep 2008 17:23 - 03 Apr 2017 20:12 #1 by olympusman
Flying Through Fire - Geoffrey Williams was created by olympusman
Flying Through Fire: FIDO - The Fog Buster of World War Two by Geoffrey Williams
Hardcover: 256 pages
Publisher: Sutton Publishing Ltd; First Edition edition (30 Mar 1995)
Language English
ISBN-10: 0750908815
ISBN-13: 978-0750908818
ORIGINAL POST BY olympuusman as below
Is it worth getting a copy of "FLYING THROUGH FIRE, FIDO - THE FOGBUSTER OF WORLD WAR TWO" ?
6 RCAF Bomber Group (organisation, airfields, squadrons, aircarft, and their 70 crashes in Belgium (location, crew, evasion lines, cemeteries, PoW Camps, etc...). Busy for a couple of years !!!!!!
09 Sep 2008 22:03 #2 by carnaby
Replied by carnaby on topic Flying Through Fire - Geoffrey Williams
I think this is an excellent book - first class coverage of a complex and unique subject. Forty pages on development, plus 170 on the fifteen English airfields. Just two pages on Epinoy (the sole system installed on mainland Europe) though.
G.
09 Sep 2008 22:14 #3 by Paul Francis
Replied by Paul Francis on topic Flying Through Fire - Geoffrey Williams
I agree with everything you say Mr Carnaby but is there any mention of Davidstow Moor?
09 Sep 2008 22:33 #4 by olympusman
Replied by olympusman on topic Flying Through Fire - Geoffrey Williams
Thanks Carnaby
I will get a copy via Abebooks !
09 Sep 2008 23:15 #5 by CDP
Replied by CDP on topic Flying Through Fire - Geoffrey Williams
Carnaby - given that recommendation, I might have to hunt a copy down.
Oh dear - the book "wish list" is getting longer again.
10 Sep 2008 10:46 #6 by carnaby
Errrr no !
Davidstow reports having had a 'temporary installation' to work alongside Ground Controlled Approach.
I would have thought that to have installed even a temporary FIDO system would take quite a long time.
The prototype GCA installation arrived at Davidstowe on 28 Aug 1943, and moved to St Eval during September as they had calibration problems at the former, hence it was there less than a month.
The St Eval FIDO was proposed in April 1943, installation began in August, and was 'nearing completion' in December 1943.
Arthur C Clarke's descriptions regarding FIDO relate to St Eval.
The book does not mention temporary systems, but describes the portable unit, developed August 1944 and used at Epinoy.
Interesting!
23 Sep 2008 21:51 #7 by olympusman
Got my copy today, looks very interesting !
Carnaby, interesting about the FIDO portable system of Epinoy... is there more info to find in another book ?
Any idea if this system was used on other ALG'S during the winter 44/45 ?
Thanks
24 Sep 2008 06:37 #8 by Milkpail
Replied by Milkpail on topic Flying Through Fire - Geoffrey Williams
Olympusman
The only other reference to portable F.I.D.O. systems I have come across is in:
Hartley, A. C. (1948) Fog Dispersal from Airfield Runways. In: Institute of Civil Engineers, The Civil Engineer in War. London: Institute of Civil Engineers.
This is the relevant section:
"Haifox” (Portable) Burners (Hartley Anglo-Iranian Fox).
It was anticipated that the Tactical Air Force would require Fido installations on the Continent after the invasion in 1944. The problem was to reduce the erection work necessary at site, and particularly the welding and concreting, by re-designing components for prefabrication, and at the same time making them suitable for aerial transport.
Coils of 1-inch tubing, 42 inches inside radius, had been tried previously for small burners. A rectangular frame of 12-inch tubing, 7 feet 6 inches long, was designed to support and feed petrol to three pairs of those coils, each 2 feet long. They were arranged in series-parallel flow in order to balance wind variations. The vaporizer, known as the "Haifox," weighed 160 lb., and was heated by 15 per cent. of its total evaporation from a single central burner pipe, down which the remaining vapour passed to 25 yards of 2-inch burner line in four screw-jointed lengths (Fig. 5, facing p. 138). Four such burners on a common valve assembly generated 30 therms along 120 yards of runway. As distortion was practically eliminated concrete anchorages were unnecessary.
Pumping manifolds and valve assemblies were mostly prefabricated, victaulic joints mainly being used on site. Orifice plates were used instead of automatic valves to simplify the control of the fuel distribution to the burners. The system was designed as if for a perfectly level airfield, but was applicable to unsurveyed airfields with variations in static head between burners by selection of the correct orifice plates.
Haifox vaporizers were later modified to develop pressure-output characteristics similar to the Haigill burners, for use as first-aid replacements for the latter when badly damaged.
Extensive use had been made of certain of the Fido burners at the home installations as flares in conditions of mist or haze, and a smaller two-coil vaporizer with 30 feet of 1-inch burner line, the "Light Portable Marker Burner," was evolved in November, 1944, to meet requests for runway or approach funnel marker flares for use at airfields without full Fido equipment. Those markers were issued to T.A.F. Wings with semi-rotary hand pumps, whilst a U.S.A.A.F. station used them with road tankers.
Regards
Mark
15 Oct 2008 18:45 #9 by olympusman
Just ended reading "FLYING THROUGH FIRE, FIDO--THE FOGBUSTER OF WORLD WAR TWO"
Great book !
15 Oct 2008 18:48 #10 by olympusman
Ooooops !
Mikpail
Thanks for your interesting details about portable FIDO
Looks like we tried as from 1946 to use some 'burning drums' in Belgium but not that sucessfull of course...
