Unable to edit my posts
20 Jan 2019 20:52 - 20 Jan 2019 20:54 #41 by David Thompson
Replied by David Thompson on topic Unable to edit my posts : testing to edit
I seem to remember that the Edit facility disappeared after an upgrade/reboot/whatever and was restored at another opportunity so I am typing in this test reply in the hope of being able to edit it or does the edit only apply to the initial thread post ? We shall see !
Yes the Edit button did appear and highlighted too . One to remember but would be useful without the need to go to a Moderator .
20 Jan 2019 21:23 #42 by Jeff Hawley
Replied by Jeff Hawley on topic Unable to edit my posts : testing to edit
David, As mentioned before, Users can only edit their posts for a limited time period once they have originally posted that post. If you require a older post to be edited you will need to contact a Moderator with the reasons for the edit and they will edit the post for you once they have reviewed the post. This is to maintain the integrity of the threads.
Vice Chairman
Director/Trustee
Community Heritage & Conservation Manager
Archives Manager
Airfield Research Group Ltd
22 Jan 2019 23:05 #43 by CornwallPhil
Replied by CornwallPhil on topic Edit facility missing ?
Yes I've noticed it missing since Christmas.
22 Jan 2019 23:45 - 22 Jan 2019 23:46 #44 by David Thompson
Replied by David Thompson on topic Edit facility missing ?
Test ; because I think the 'Edit' button only appears when you post ?
If not , Jeff answered a similar post on a similar thread here which should probably be merged ? ;
www.airfieldresearchgroup.org.uk/forum/f...osts?start=30#157521
***Yes the 'Edit' button appeared when I submitted the post so hopefully that will answer your question ?***
23 Jan 2019 02:19 #45 by TerryClark
Replied by TerryClark on topic Edit facility missing ?
Has re-appeared on my machine now.
23 Jan 2019 10:23 - 23 Jan 2019 10:27 #46 by netcompsys
Replied by netcompsys on topic Edit facility missing ?
(Threads merged)
The Edit button on posts is now only available to Users for a short time after the user first makes that post
This is by design and not a side effect of an forum software upgrade
It has been implemented because we have had cases where a user has decided to edit his posts so as to remove his text and images,
This is a regrettable but necessary step to maintain the integrity of the threads and discussions
If you find posts of your own or others that need editing or correcting please get in touch either directly or using the Report to moderator link bottom right of each post and fill in the form
I have already fixed a couple of Terry's
Edit
A Tip for all of you, if you use Quote rather than Reply when answering a post, the post you are replying to becomes part of your post so the context of you reply can be clear. You can edit the quote to remove the bits not relevant to your reply
23 Jan 2019 12:23 #47 by Peter Kirk
Replied by Peter Kirk on topic Edit facility missing ?
Following on from Kevin's post, when editing a QUOTE reply make sure the quoted bit retains the square brackets around the quote code as it is easy to accidentally edit them out, especially the closing code which should be [/quote].
If the quote also contains a quote you may want to edit out one of the quotes so make sure you remove the correct name in the opening quote code and its corresponding closing quote code.
23 Jan 2019 20:30 #48 by netcompsys
From my own Testing, The Edit button and function is present for approximately 10 minutes after you originaly submit your post
After that, the function is not available
If you want to have your post edited please contact a moderator directly or use the Report to moderator Link at the bottom left of each post
If you message an individual moderator, then they will action it when they can
if you use the Report link, all moderators will get the message
You could alternatively re-post your original post in corrected form and let us know as above and we will remove the surplus post
The following user(s) said Thank You: Alex Brown
Time to create page: 0.064 seconds
