More buildings on the Virtual Workbench
22 Apr 2012 19:13 #181 by YellowPinkie
Replied by YellowPinkie on topic More buildings on the Virtual Workbench
That's quite a shine on that missile, is that to help with punching through the atmosphere?
Nice work, couldn't you bring the Landy a little closer?
22 Apr 2012 19:29 #182 by P Bellamy
Replied by P Bellamy on topic More buildings on the Virtual Workbench
The Landy is there simply to break up the tarmac between the hangars, I'll maybe move it later.
As for the shiny Thor, it's the same surface all over as in the earlier grab, an off-white "paint" with a thin "clearcoat" on top.
I'm running another render now, with the sun shifted around the other way to see if that comes out better... ;)
23 Apr 2012 10:38 #183 by Peter Kirk
Replied by Peter Kirk on topic More buildings on the Virtual Workbench
I marvel at what can be done in Sketch-up and simialr packages. I tried to produce a simple 7ft eight corner radar reflector. Failed after creating square number one.
23 Apr 2012 11:47 #184 by YellowPinkie
Ha ha. sketchup is a bit tricky to start with in getting the geometry on the right face, and the tutorials are not as good as they could be. My advice is to work through the examples to see how they work, then apply that to your RADAR reflector.
Or call in a favour with PB...:lol:
23 Apr 2012 11:54 #185 by Chris Lowe
Replied by Chris Lowe on topic More buildings on the Virtual Workbench
I don't think any of us can match PB's skill with sketchup.
28 Sep 2012 19:53 #186 by P Bellamy
First draft of the RIM Building's companion, the Technical Supply Building.
This was basically the main stores building for each wing's Thor-specific items.
One end had a pair of loading ramps built, plus a large room either side of the doors, one for external stores the other for external issues.
This area was seperated from the rest of the hangar by a chain-link fence with vehicle gates in the centre.
The octagonal area and the two rectangular areas are marked on the building drawings, unfortunately they are not identified at all.
28 Sep 2012 20:26 #187 by YellowPinkie
So when do we see a full on Wing HQ in SketchUp?
28 Sep 2012 20:52 #188 by P Bellamy
You'll be wanting an S&I Building doing next...
Oh wait, there it is:
28 Sep 2012 21:33 #189 by YellowPinkie
That's uncanny, I took a photo inside the North Luffenham S&I building by poking my camera through a slot beside the roller shutter (the lights were on inside...) It looks just like this.
I'll not post the picture up here because of what was inside, but watch your e-mail in the next half an hour...
29 Sep 2012 00:32 #190 by P Bellamy
Ta for those Steve.
It looks like the corrugated panels on the outside of the assembly hall aren't just cosmetic cladding, but have replaced the rendered HyRib panels entirely.
We still have to ascertain exactly what the S&I Building was for.
My best guess is it was the primarily the warhead inspection and maintenance facility, as I still can't see how you'd get a complete missile inside unless it was on a handling dolly.
Time to create page: 0.063 seconds
