More buildings on the Virtual Workbench
10 Dec 2008 12:27 #1 by P Bellamy
More buildings on the Virtual Workbench was created by P Bellamy
These models are done in Google Sketchup.
It's by no means the best software, but it is free and pretty simple to use, especially for my purposes.
Gym and Chapel 4911/42 and 15424/41:
J/K Type Hangar (rough draft from MoD drawings):
T-2 Hangar, Glazed:
Operations Block complex for Bomber and OTU Stations 228/43:
Control Tower 12779/41:
Or for when you get really bored........
A small part of the 2nd Strategic Air Depot Abbot's Ripton incomplete model:
The following user(s) said Thank You: KeithBrown
10 Dec 2008 13:16 #2 by mawganmad
Replied by mawganmad on topic More buildings on the Virtual Workbench
Excellent results - and all from free software, well done. Really like the Chapel/gym.
Might be worth you starting a thread or posing your pics on the Airfield Structure Audit (as built) thread illustrating the different building types.
What are the yellow boxes on the watch tower roof - I'm thinking equipment stowage boxes?
10 Dec 2008 13:19 #3 by JCB
Replied by JCB on topic More buildings on the Virtual Workbench
Paul: You have been reading my mind! Those models are fantastic and really help you to visualise what these things looked like, both inside and out. Will have to see if I can work out how to use that software myself. Well done for showing us the fruits of your labours.
10 Dec 2008 13:35 #4 by Stevo
Replied by Stevo on topic More buildings on the Virtual Workbench
Those really are great Paul and it's very interesting to see the internal arrangement. I wish I could add that much detail to my Flight Simulator models.
10 Dec 2008 13:40 #5 by Paul Francis
Replied by Paul Francis on topic More buildings on the Virtual Workbench
Very good paul, it a shame about the newton rings on the Nissen huts, I wonder if you had used paint.net, the vertical line would'nt be so jagged and you wouldn't have the ring effect. Excellent though, the shaddows make them look really good.
Message to Richard, I know the crew rooms at upwood dont have the annexe but the two main huts are there and these would help paul (you just can't get the staff).
10 Dec 2008 14:07 #6 by P Bellamy
Replied by P Bellamy on topic More buildings on the Virtual Workbench
Again, thanks,
The pictures above are just screen grabs, reduced in size to suit this forum.
The distortions on the nissen hut roofs are a side effect of the old method of applying the corrugated effect by means of a render. The crew room model is having proper extruded corrugations added, although I'm struggling at the limit of procesor capacity while it actually draws each section. I guess that's something I ought to expect as they are being built full-scale.
The yellow boxes on the control tower roof are the spare runway heading boards for the frame.
Sketchup also lets you do fun things like this:
My current project is building Deenethorpe in it's entirety, including the dispersed sites, for the 401BG Association. Although I'm building it so as to be viewable in Google Earth, after looking at the Flight Simulator pictures on other threads, I think that might be a better way to go about it and be more user-friendly for the Veterans.
The Virtual Deenethorpe model is only about 40% complete at basic building level and is almost 150Meg as is.... when I start adding windows, doors, stovepipes etc. it might just end up too large to be of any use. :roll:
TTFN,
10 Dec 2008 14:10 #7 by Stevo
That ring effect is probably the limit of either the drawing engine supplied with Google sketchup or a limitation of the graphics card. I get the same effect in Gmax, the program I use, especially if I use a texture that has close vertical lines and then zoom out away from the model.
PB; If you need any advice re flight sim just ask. I've been building flight sim models for a good number of years now and its a great tool to use for recreating airfields.
Stevo ;)
10 Dec 2008 14:24 #8 by P Bellamy
Thanks Stevo,
I'll be in touch. ;)
11 Jan 2009 23:44 #9 by P Bellamy
While the Crew Room and a couple of others are still awaiting AM Drawings to arrive, here's a couple I've been working on in my spare time.....
I'm sure someone will shout up with the type and drawing numbers. :wink:
TTFN,
12 Jan 2009 00:23 - 13 Mar 2018 21:07 #10 by Stevo
Hi
The one in the first pic, I built one for those for a flight sim version of Binbrook. I don't know what it is or what it was used for originally, I've been trying to find out. I think in later years it was used as RAF Binbrooks rugby club.
Here's one of NorwichPaul's picture of that very building at Binbrook it was behind the institute.
Here's the version I made for Flight sim.
Stevo ;)
Time to create page: 0.062 seconds
