Minature preservation: 4mm Scale
22 Sep 2017 14:47 #11 by Able Mabel
Replied by Able Mabel on topic Minature preservation: 4mm Scale
This is the very latest view of the station layout . . . STILL work in progress
Currently measures 12ft front to back and from the T2 in the left corner to the extreme right its 16ft.
The pre-war built 25yds range need a little more to complete
Flying Control
General views
I am just about to finish the Eight blast shelters and construct another Air-raid shelter
The following user(s) said Thank You: carnaby, Peter Kirk, PETERTHEEATER, kebecker, Ossington_2008, Chris Lowe, ianbache, netcompsys
24 Sep 2017 10:07 #12 by ted angus
Replied by ted angus on topic Minature preservation: 4mm Scale
Just beyond belief, fantastic .
best wishes
The following user(s) said Thank You: Able Mabel
12 May 2020 11:22 #13 by MarkPolles
Replied by MarkPolles on topic Minature preservation: 4mm Scale
Could I ask where you found the dimensions for the "T2" hangar please?
I'm looking for external dimensions for the 1934 Type C and the Type D.
I've been asked to produce a pair of 1/72 scale low-relief frontages for a chap that collects die-cast 1/72nd aircraft.
12 May 2020 22:05 #14 by Able Mabel
Mark
There are official drawings for each of the hangars you mentioned so a source is available to build which ever type you want.
RAFM Hendon is a safe bet unless the ARG archives can provide copies for you ??
On the Britmodeller forum a chap is current building a 'C' Type hangar as a backdrop for photographs, have a look on there, it may help
regards
Ian
The following user(s) said Thank You: MarkPolles
16 May 2020 17:03 #15 by Paul Francis
Replied by Paul Francis on topic Minature preservation: 4mm Scale
Mark we have the drawings that you have requested and many thousand others but we are unable to copy them or even access the originals owing to us having to move and now the lockdown. The room they are in is not accessible owing to to it being crammed with archives. If I find any digitised plans with the dimensions that you are after, I will PM you.
16 May 2020 17:21 #16 by Peter Kirk
Replied by Peter Kirk on topic Minature preservation: 4mm Scale
The MOD website had some colourful CAD drawings of all the hangar type extant on their sites. However they seem to keep moving the blighters around as all the links I had were dead so were deleted months ago.
This might help though:
webarchive.nationalarchives.gov.uk/20121...FBF9CF556/0/fs16.pdf
The following user(s) said Thank You: PETERTHEEATER, MarkPolles
Time to create page: 0.052 seconds
