Relocated Hangars
21 Oct 2009 20:21 #51 by Paul Francis
Replied by Paul Francis on topic Relocated Hangars
Robins hangar (At Exeter USASB).
Type Robins Type 'B' Aircraft Hangar 2204/41 & 6874/43
The Robins hangar (now called Robin) is a small steel-framed aircraft dispersal
shed normally found on Aircraft Storage Units and Satellite Landing Grounds.
The standard arrangement required 'A'- shaped wall frames to be spaced at 12ft 6ins centres to form five bays. Roof and wall sheeting were normally 24-gauge blackpainted corrugated sheeting. At one end only, doors (clear height 14ft) in four leaves open full width (clear span 44ft) along floor and upper guides which project out from the building. The upper guide is supported by a braced outrigger.
The price for a single standard length hangar in 1943 was as follows:
• Steel frame £545
• Delivery and erection £180
• Foundations (stanchions only) £50
• Total £775
21 Oct 2009 22:38 #52 by Chris Lowe
Replied by Chris Lowe on topic Relocated Hangars
You can download the drawing for a Robin hangar here www.defence-estates.mod.uk/publications/.../330-Layout1.plt.pdf this may help you as well.
23 Oct 2009 17:41 #53 by HelmutSparrow
Replied by HelmutSparrow on topic Relocated Hangars
Thanks you for replies, but have studied photos and the hangar in question is much smaller than the standard dimensions quoted. When was the Robin hangar first builded?
HS
23 Oct 2009 20:55 #54 by Paul Francis
1941 to drawing 2204/41 (the 41 after the forward slash is the year).
23 Oct 2009 21:02 #55 by Paul Francis
HelmutSparrow, your building sounds too small to me to be a WW1 hangar, more like a WW2 hut with canted sides called a Ministry of Supply Living hut. The span is 17ft 3in with a length of 60ft.
23 Oct 2009 21:14 #56 by John Cooper
Replied by John Cooper on topic Relocated Hangars
If it has nt already been mentioned Wattisham QRA 'shed' was dismantled and is now housing two Lightnings at Bruntingthorpe
23 Oct 2009 22:06 #57 by HelmutSparrow
I forgot to mention that the hangar I describing was used as an armoury for RFC Minchinhampton or so I am informed. So not use as a hangar for aircraft and very small. It looks like a Robin and has same type of A-frame roof trusses but size is much smaller. I will ask permission to post photos on here but I think my friend wants to keep off the net for the security of his valuable aircraft.
HS
03 Nov 2009 17:11 #58 by jason
Replied by jason on topic Relocated Hangars
Has anyone any information as to where the Blister hangars at both Little Snoring and Rattlesden originated. They are used by the Flying and Gliding clubs.
08 Nov 2009 09:03 #59 by PETERTHEEATER
Replied by PETERTHEEATER on topic Relocated Hangars
This Blister at Insch, Scotland is reported to have come from Fordoun
www.bing.com/maps/#JnE9eXAuaW5zY2glMmMrc...NzE0MDY1NTUxNzU3ODM=
Sorry, the link wont got to the marked spot so, come south from Insch down the B992 to Auchleven then west on the unmarked road toward Leslie. Halfway down the road and south of it is Insch airstrip (?) and you can see the Blister.
12 Nov 2009 10:42 #60 by PETERTHEEATER
Airfield Review No 61 had a report on an Admiralty Type G Shed relocated from RNAS Newhaven to Wimbledon.
Is it still there?
wtp2.appspot.com/wheresthepath.htm?lat=5...2324&gz=18&oz=9>=1
Time to create page: 0.045 seconds
