Relocated Hangars
27 Sep 2014 17:21 #141 by Norbert_Nutcracker
Replied by Norbert_Nutcracker on topic Relocated Hangars
There are a pair (I think. from memory) of big black Robbin Hangars from Hethel (Unsure, but so close to Lotus works to likely be the correct one) used for chemical and grain storage.Its right next to a country road. I will get a picture next time im in the area.
25 May 2016 10:34 #142 by Tim Hill
Replied by Tim Hill on topic Relocated Hangars
Crabtree or sometimes Crabbtree is the name of the wood where the base was located
25 May 2016 13:14 - 26 May 2016 15:21 #143 by Evelyn
Replied by Evelyn on topic Relocated Hangars
A number of ex-airfield hangars can be seen at Richardson's boatyard in Stalham, North Norfolk:
Blister hangar originally from RAF Metfield
Blister hangar from RAF Seething
They also have two T2s, one from RAF Metfield, which is referred to as the "Black Hangar" and nowaday houses vehicle maintenance, a machine shop, an engineering workshop, an electricians' workshop, the window workshop, wood working machinery and stores. The following information was kindly provided by Mr. Robert Richardson: "This hangar came from Metfield. It has always been referred to as “The Black Hangar” due to it being clad in corrugated tin painted black; it was re-clad in silver in 2013. It is a T2 Aircraft hangar. It has had some upright sections removed to lower the height (by 12ft) but the sections which were removed were made into additional three trusses and used to extend the overall length by 31ft taking the overall length up to 271ft from the original 240ft."
and another of unknown origin, now serving as the boatyard's wet shed. It was lowered in height by 18ft and was extended by six more trusses to make the overall length 303ft. According to the manager it is Europe's largest wet boat shed.
They also have a Butler shed which was bought crated up and in new condition and was originally intended for a wartime airfield but never erected anywhere previously (source: Mr Robert Richardson). Lean-to extensions were added at the boatyard; they are not original.
The following user(s) said Thank You: Paul Francis
25 May 2016 14:15 - 25 May 2016 14:17 #144 by Paul Francis
Replied by Paul Francis on topic Relocated Hangars
Evelyn, I dont suppose you can get inside and photograph the framework of the Butler hangar - this is almost certainly the only example left in the UK?
25 May 2016 14:59 #145 by Evelyn
Oh, how interesting. Anything else you would like me to photograph besides the framework, should I be successful in obtaining permission to take interior pictures?
25 May 2016 16:07 #146 by Paul Francis
Look for nameplates on the stanchions.
26 May 2016 07:12 #147 by PETERTHEEATER
Replied by PETERTHEEATER on topic Relocated Hangars
Re the Butler Shed/Hangar - Has the original width been increased with the addition of 'wings on each side?
26 May 2016 08:52 - 26 May 2016 08:56 #148 by Evelyn
Yes. Mr Richardson, the owner, who gave me all the details when I took these pictures about two years ago, told me that lean-tos - what you refer to as wings - were added.
26 May 2016 10:49 #149 by JCB
Replied by JCB on topic Relocated Hangars
Evelyn - ten out of ten for original research.
26 May 2016 11:07 #150 by PETERTHEEATER
Thanks Evelyn, heavily modified but maybe the lateral walls of the original shed are still in place with, perhaps, access doors into the annexes.
Time to create page: 0.076 seconds
