Avro Vulcan
31 Mar 2016 20:32 #491 by Bloodhound1949
Replied by Bloodhound1949 on topic Avro Vulcan
Thank you for the comments,
I wonder if the true ceiling was perhaps somewhere between the two figures quoted ?..It would be interesting to hear from ex aircrew types................
Thank you,
Tony.
31 Mar 2016 21:35 #492 by netcompsys
Replied by netcompsys on topic Avro Vulcan
Thank you,
Tony.
For ex aircrew you probably need to ask that question on prune
A Google search suggests 56K is probably about right, additionally similar searches for aircraft like the Canberra PR9 suggest that 80k is unlikely
01 Apr 2016 09:22 #493 by canberra
Replied by canberra on topic Avro Vulcan
I worked with an ex Vulcan captain, I remember him saying he got to 60,000ft in a Vulcan.
As for the definition of "service ceiling" I was lead to believe it was the point at which the rate of climb drops to under 200feet per minute.
01 Apr 2016 10:07 #494 by Dietmar Morley
Replied by Dietmar Morley on topic Avro Vulcan
I read somewhere that the highest altitude achieved by a Vulcan was around the 64-65k mark.
01 Apr 2016 15:44 #495 by Peter Kirk
Replied by Peter Kirk on topic Avro Vulcan
I did see a Vulcan pilots notes on eBay the other week, although I was a bit suspicious about it. The service ceiling must have been below the maximum to allow for varying conditions at that height. It would be interesting to read the test pilots version as that may be where some of the higher figures stemmed from, although I would have thought 80,000ft is still way too high. Would it also depend on mark and engine version as I seem to recall engines having a ceiling independent to the airframe but that must be a formula driven height?
01 Apr 2016 16:47 - 01 Apr 2016 19:55 #496 by Dietmar Morley
I think ultimate ceiling is pretty much only to do with engines and air intakes. They need oxygen and without it they can't function. Different engines perform differently in the rarified atmosphere.
Having said that a big heavy airframe needs to be kept up in the air when there isn't much air to create lift. So lots and lots of engine power is needed.
That's probably why it's the smaller planes that got higher (x-15, starfighters,phantom)
01 Apr 2016 17:09 #497 by Bloodhound1949
The Olympus 301 was derated for normal service use,more power was available from the engine and I was just wondering if the aircraft may have been used for some sort of intelligence/probing mission..The North Cape is very close to the former Soviet Union ...probably a load of nonsense on my part !
Thank you all for the informative remarks.
02 Apr 2016 09:37 #498 by canberra
27 Squadron were made the MRR(maritime radar recce) unit when the Victors finished in that role so they could have been used around North Cape.
09 Apr 2016 20:07 #499 by netcompsys
Vulcan B2 cockpit at the jet Age Museum Staverton June 2014
10 Apr 2016 10:18 #500 by canberra
Imagine sitting in that cockpit for 16 hours during the BLACKBUCK missions!
Time to create page: 0.060 seconds
