WW2 Goose neck flare ?
22 Aug 2015 01:49 #11 by PETERTHEEATER
Replied by PETERTHEEATER on topic WW2 Goose neck flare ?
Thanks for finding the original thread Carnaby.
22 Aug 2015 06:34 #12 by Ian L
Replied by Ian L on topic WW2 Goose neck flare ?
Is this another one by a different manufacturer ? hinged top handle, hinged cover & a goose neck.
Attached files [IMG]/community/163488=23948-$_14 (2).jpg[/img]
Pilot & WW2 vehicle restorer.
22 Aug 2015 09:16 #13 by PETERTHEEATER
Your images wont open for me Ian. Tried saving one and zooming but the definition is bad.
22 Aug 2015 10:21 #14 by Ian L
Hi David I will PM you the link later, regards Ian
22 Aug 2015 11:12 #15 by PETERTHEEATER
Ian, I have just cleared my full Inbox. Try again
22 Aug 2015 15:33 #16 by Ian L
Just sent again Peter, regards Ian
23 Aug 2015 08:22 #17 by PETERTHEEATER
Replied.
23 Aug 2015 23:49 #18 by P Bellamy
Replied by P Bellamy on topic WW2 Goose neck flare ?
I'm pretty sure this ISN'T a gooseneck flare, but a simple filling can of some description.
Assuming the stamping is an AM stores reference, Section 21 is for Barrack Equipment
Subsection 21G/xxx covers "Hospital Equipment, excluding medical & surgical supplies" which doesn't sound right at all, more likely is 21C/xxx "Metalware".
Goosenecks with marked stores references are usually in Section 4 (Aerodrome Equipment), for example 4C/1273 is the reference for the regular round pattern type with the round lid.
24 Aug 2015 10:33 #19 by PETERTHEEATER
No doubt in my mind that the stamping is a Stores Section and Reference. Presumably there is an RAF Air Publication 1086 in the archive(?) and yes, the 'G' could be a 'C' either way that would confirm that it is probably just a Can, Filling to use the RAF nomenclature:-P
Section 4C, I feel sure was Ground Electrical Equipment whereas Section 4G was Ground Equipment. Of course, this system of cataloguing was superseded by the so called NATO numbering so an AP 1086 pre-1970s would be required to confirm.
24 Aug 2015 10:48 #20 by P Bellamy
4C: Airfield Equipment
4G: Aircraft Servicing and Ground Handling Equipment
4GA: Winches, bomb and spares
4GB: Aircraft standard ground armament handling equipment
No copy of AP 1086 in the collection as yet I'm afraid, would be useful to have though. ;)
Time to create page: 0.064 seconds
