Mystery floating thingie - flying boat related?
22 Jul 2015 19:52 #11 by Peter Kirk
Replied by Peter Kirk on topic Mystery floating thingie - flying boat related?
I'll check to see if I have plans for Druridge Bay ranges and see if Marker Floats were mentioned on similar ranges.
22 Jul 2015 20:16 #12 by Bigbear
Some thoughts on the acronyms:
OHM: Outer Hazard Marker
If the O was a Q: Queens Harbour Master
Which would make KHM: Kings Harbour Master
23 Jul 2015 07:38 #13 by Peter Kirk
Harbour Master sounds good but it sounds less like a military marker then.
The Druridge Bay plans I have don't show buoys let alone marker floats so unable to confirm or deny the use of marker floats there.
23 Jul 2015 08:45 #14 by IanDDavidson
Replied by IanDDavidson on topic Mystery floating thingie - flying boat related?
Most moorings incorporated an swivel joint so it would probably have turned with the tide.
Peter,
That is an interesting observation. I recall from my RYA training that one of the tricks to know the direction of the tide and gauge its approx speed is to watch how the water impacts a buoy. With the standard tall round ones, they tip from the vertical and you can see through binoculars that the water is rippling up one side and lower on the downstream side.
The big cylindrical buoys in the Thames are yellow on top and black on the bottom so easy to gauge the flow from the angle of the line where the two halves meet.
With the design in the photograph the boat shape will swing with the tide and if it was hooked to a mooring buoy makes it very easy to quickly determine the direction of the tide. The speed of the tide under normal conditions is available from published tables. If it were intended to assist flying boat operations the shape of the boat-buoy and its relationship to its mooring buoy would be easy to spot.
I hope we have someone here who has seen one in action; it's an interesting puzzle.
23 Jul 2015 10:31 #15 by Bigbear
Is anyone on the RAF forum I linked to in the earlier post? They could question the person who posted the quote.
23 Jul 2015 15:37 - 01 Jul 2017 13:59 #16 by Peter Kirk
A photo of the various anchors used and also the swivel joints. The swivel joints would also prevent the chains kinking and would require regular maintenance, as would the chains and anchors.
26 Jul 2015 09:41 #17 by Peter Kirk
I came across a reference to a marker boat in connection with a torpedo dropping range. As the target ship was also mentioned I assumed it was a different vessel. Target ships were normally moving so I have no idea where the marker boat fitted in.
PS I moved the Haile Sands posts to a new thread.
02 Jul 2016 17:13 - 02 Jul 2016 17:36 #18 by Adrian James
Replied by Adrian James on topic Mystery floating thingie - flying boat related?
A few pictures of similar, although larger examples of such floats on the Yangste River in 2016
02 Jul 2016 18:08 #19 by Peter Kirk
Those are more likely to be marine markers and I wonder if the boat is used to store batteries. Is there an international standard for marine buoys failing that does anyone have a sea chart of that portion of the Yangste?
02 Jul 2016 18:26 #20 by Adrian James
The photographs show just a selection of the many hundreds(?) we passed. They marked the channel and obstacles. Several hundred miles from the open sea!
Time to create page: 0.397 seconds
