miscellaneous concrete ?
10 Apr 2011 20:20 #1 by ianbache
miscellaneous concrete ? was created by ianbache
Has anybody got any ideas on these two items, i found them on a building base at site 2 at Llanbedr,
Mr Carnaby, any ideas could they be water basins ?
10 Apr 2011 20:31 #2 by WJT
Replied by WJT on topic miscellaneous concrete ?
Bases for coal/coke stoves from Nissen huts?
10 Apr 2011 20:43 #3 by Denis
Replied by Denis on topic miscellaneous concrete ?
Confirm that, pot belly stove trays.
10 Apr 2011 20:59 #4 by ianbache
Replied by ianbache on topic miscellaneous concrete ?
Thank you very much, why the different shapes though, any ideas
regards Ian
10 Apr 2011 21:04 #5 by P Bellamy
Replied by P Bellamy on topic miscellaneous concrete ?
The pointed one fits in the corner of a room, the octagonal one is usually in the centre of a room or away from the wall.
Those that fit against a straight wall are normally D-shaped, although the octagonal ones could be used if nothing else was available.
10 Apr 2011 21:12 #6 by ianbache
Thank you PB thats much appreciated,
11 Apr 2011 09:19 #7 by mawganmad
Replied by mawganmad on topic miscellaneous concrete ?
Excellent find and response, seen these myself and wondered what they were!
01 May 2011 18:51 #8 by ianbache
Hi PB
could this be the D shaped stove tray this also at Llanbedr and in the corner of a concrete base
03 May 2011 00:37 #9 by P Bellamy
That's an interesting variant on the usual room-corner pointed type, almost as if it's designed to be bonded into the wall.
The D-shaped ones are basically the regular octagonal type but with one of the narrow ends being flat rather than having angled corners.
Paul
03 May 2011 07:01 #10 by PETERTHEEATER
Replied by PETERTHEEATER on topic miscellaneous concrete ?
Sniff!... obviously for an Officer's quarter.
