Which Halifax airfield?
28 Jan 2010 15:59 #1 by carnaby
Which Halifax airfield? was created by carnaby
...is this?
They are using Runway 26, then fly over East Moor. Thought it might be Linton, but runways are wrong.
One post says Elvington - runway OK, but tower doesn't look right.
Then again it could be more than one airfield.
28 Jan 2010 18:33 #2 by Granite
Replied by Granite on topic Which Halifax airfield?
If the commentary is to be believed only airfields that close to Eastmoor would be Linton on Ouse and Tholthorpe and possibly those in the Dishforth area. Hangars looked wrong for Linton, Topcliffe and Dishforth and its too flat for others such as Skipton on Swale so I'd go for Tholthorpe! Its a brilliant clip....
28 Jan 2010 18:38 #3 by Alan Clark
Replied by Alan Clark on topic Which Halifax airfield?
I would say Elvington, based on the aircraft we saw briefly with a full squadron code. The squadron identifier was L8 which was 347 at Elvington.
Alan Clark
Peak District Air Accident Research
www.peakdistrictaircrashes.co.uk
28 Jan 2010 19:53 #4 by Paul Francis
Replied by Paul Francis on topic Which Halifax airfield?
Some of it may have been at Elvington, but the control tower shots were probably not as there is too much glass in the control room. Elvington has a CT used for night operations and required one with small window openings, while the film shows a control room with a mass of glass. I had thought it might have been an additional control room, perched on the roof. I noticed the far door open but it looked like a balcony beyond the door though I admit it could easily have been the roof.
28 Jan 2010 21:21 #5 by Granite
The view out of the window at approx 5.41 looks a bit like the emergency field at Carnaby. The bearing of 115 degrees and 38 miles To Bridlington would put him near Ampleforth......
28 Jan 2010 21:29 #6 by Peter Kirk
Replied by Peter Kirk on topic Which Halifax airfield?
28 Jan 2010 22:35 #7 by David Thompson
Replied by David Thompson on topic Which Halifax airfield?
I think there are a few red herrings in there too ? Look at the Halifax shown taxying at 4:12 and then taking off at 5:00 and its flypast . It has no mid upper turret and an extended bomb bay very similar to a late Mark 7 , 8 or 9 ? For some reason I was thinking Tarrant Rushton ? There is some FAF footage at Elvington in there and it appears in a video film I bought from YAM at Elvington which was commercially available and probably still is but now on DVD , the cover photograph is a FAF Halifax over the Eiffel Tower .
29 Jan 2010 10:33 #8 by Able Mabel
Replied by Able Mabel on topic Which Halifax airfield?
Have another listen because i'm sure at 4.08; he states that there are
'other aircraft in the RUFFORD circuit'
29 Jan 2010 14:03 #9 by carnaby
Replied by carnaby on topic Which Halifax airfield?
A few thoughts
Yes, it is a complete mismatch, events in order are:
Take off on rwy 026 from 'Stopgap'
We get 'airfields in the circuit at Rufforth' on take off (4.07)
Is there a 'J' hangar in background (4.26 and 5.02)?
Heads north at 5.29
Then we see Carnaby - three miles from Bridlington (5.40)
At 5.50 set course for Bridlington (38 miles 115 degrees), puts them a few miles north of Helmsley
Interesting airfield described as East Moor at 6.10. Not entirely convinced. I think the aircraft is heading south, in which case there are dispersals to the left where the tech site should be. Could be wrong.
At 6.23 the controller says something about 123.54. That sounds like a 'modern' VHF airband frequency. I may be totally wrong, but thought WWII bombers used HF for communications. (Fighter Command definitely used VHF, as did 617 on the Dams Raid I believe.)
02 Feb 2010 15:45 #10 by CDP
Replied by CDP on topic Which Halifax airfield?
At 3:24 it actually shows a Lancaster's flight engineers panel. It's a small clip from one of the Jack Currie docs of the 1980s. Likewise at 6:07 is another clip from Currie's docs (it's PA474).
Good little film though.
Time to create page: 0.077 seconds
