Devices on Old ATC
30 Aug 2022 11:40 - 30 Aug 2022 12:13 #1 by Vostok
Devices on Old ATC was created by Vostok
Hello,
This one is an old picture of airfield control tower in my city. I'm not quite familiar with aviation equipment what are these things are and the uses. I only know the windsock and searchlight, but didn't know the specific model. I hope any of the members here could help me identify these items here, thanks.
01 Sep 2022 19:47 #2 by Paul Francis
Replied by Paul Francis on topic Devices on Old ATC
There is three options for the first pic left side. The ball on the mast (if its red) could indicate that parachute dropping is in progress. It could also mean that the Duty Flight is here (if its a yellow ball). Further it could indicate that there is a vehicle obstruction but it would normally be a disc having another disc at right angles to the first ie in cruciform shape in section.
The following user(s) said Thank You: Vostok
01 Sep 2022 20:49 #3 by netcompsys
Replied by netcompsys on topic Devices on Old ATC
From an almost duplicate message from the OP, this is in Bandung, Indonesia
01 Sep 2022 20:58 #4 by netcompsys
And probably dates from the 1930s
Martin B-10 bomber of the Royal Netherlands East Indies Army Air Force at Andir airfield (1937)
Via www.wikiwand.com/en/Husein_Sastranegara_International_Airport
The following user(s) said Thank You: Paul Francis
02 Sep 2022 20:06 #5 by Vostok
Replied by Vostok on topic Devices on Old ATC
Thank you for the explanation. After doing a little bit of searching I found it called Cane Balls, and also the top part of the tower might be a beacon light!
08 Oct 2022 22:24 #6 by TerryClark
Replied by TerryClark on topic Devices on Old ATC
The large searchlight on top of the roof is possibly an Aerodrome Beacon (not to be confused with an Ident Beacon); 2 sided and rotates showing red (military) or green (civil) one side and white the other side.
