Concrete rectangles at the ends of runways.
10 Mar 2021 08:38 #21 by ianbache
Replied by ianbache on topic Concrete rectangles at the ends of runways.
Llanbedr had three arrester barriers on rwy 36/18 as it was then and rwy 33, for the use of Valley touch and go practice and Llanbedr unmanned aircraft, ie Meteor U15 U16 and Jindivik
www.google.com/maps/@52.795152,-4.122686,282m/data=!3m1!1e3
www.google.com/maps/@52.814553,-4.1286535,282m/data=!3m1!1e3
www.google.com/maps/@52.8072304,-4.1187387,196m/data=!3m1!1e3
Regards Ian
To be pedantic, the third barrier was on runway 15 not 33!!
Terry you are quite correct, should of picked that up, because thats my end of the Rwy where I am, cheers Terry
11 Mar 2021 12:33 #22 by 698
Regards Ian
These look to be a later type to one ones I was referring. Valley and some other bases have these and evidence of the the older type. I note these 'later' barriers seem to be at the end of the tarmac.
12 Mar 2021 10:05 #23 by TerryClark
Replied by TerryClark on topic Concrete rectangles at the ends of runways.
I can remember when they replaced our Mk 6 barriers with what were intially called Mk 12s but were then re-named Type A barriers and they did indeed put in new concrete bases for the stanchions which were closer to beginning of the paved surface.
14 Mar 2021 16:40 #24 by 698
From the limited info I have to hand by 1982 there seems to be a mix of types being used.
As selection of airfields in 1975 for example Binbrook,Colishall Valley and Wattisham had Safebar Mk6.
By 1982 Binbrook and Coltishall had Mk12 'A' while Wattisham still had Mk6 as did Valley and Leuchars
So I wonder if 1982 was around the time period that they changed over to the Mk12.
Time to create page: 0.057 seconds
