Help - in identifying this airfield
29 Dec 2016 18:13 - 30 Dec 2016 08:58 #1 by Linton Lad
Help - in identifying this airfield was created by Linton Lad
Can anyone help identify the airfield
Many thanks from linton lad
29 Dec 2016 20:42 #2 by REF
Replied by REF on topic Help - in identifying this airfield
Looks like factory hangars on the right, J or K Sheds on the left and storage shed. Is it a depot of some description? The railway should give it away but I can't place it.
29 Dec 2016 21:23 #3 by Linton Lad
Replied by Linton Lad on topic Help - in identifying this airfield
People was saying its yeadon from a fb group its on. So thought id come ask in the right place.
Hard to make out what aircraft are in the bottom field too
29 Dec 2016 21:34 #4 by Linton Lad
Bit of a puzzle really.
Other guesses were finningly and fenton. Which i know myself aint right.
Sure a answer will surface :)
29 Dec 2016 21:36 #5 by REF
It is Hawarden, Flintshire
The following user(s) said Thank You: Linton Lad
29 Dec 2016 21:39 #6 by Linton Lad
Cool. Saw your post on the group too.
Ta bud
29 Dec 2016 21:40 #7 by REF
Pleasure :-)
30 Dec 2016 08:03 #8 by PETERTHEEATER
Replied by PETERTHEEATER on topic Help - in identifying this airfield
Looking southeast; the Vickers Armstrong factory sheds are at centre right.
The 1945 RSP shows taxiways leading to multiple frying pan dispersals in the area where the aircraft visible in the bottom left are positioned suggesting an early war date for the photograph.
30 Dec 2016 11:06 #9 by Dave Smith
Replied by Dave Smith on topic Help - in identifying this airfield
The aircraft at the bottom are new Wellingtons dispersed from the Vickers factory. The runways were built during 1941 and in the photo work seems to be still in progress on them. The original short runway for Vickers can be seen on the extreme right heading between the factory and the flight shed. Until the 1980s/90s it was still known as the Vickers Track but has now changed to a boring ICAO-standard Taxiway Alpha which becomes Bravo after it crosses the main runway.
30 Dec 2016 13:51 #10 by David Thompson
Replied by David Thompson on topic Help - in identifying this airfield
There is a most excellent site plan in the book 'Hawarden - A Welsh Airfield 1939 - 1979' by a certain David J Smith ! The dispersal in the foreground was known as The Beeches and then the sites numbered clockwise from there from 1 to 5 with as PTH says , the Vickers Armstrong factory at top right between Sites 3 and 4 .
The book is long out of print but well worth getting a copy if you can , well illustrated too .
