What is this Aircraft?
25 Nov 2016 21:28 - 26 Nov 2016 09:40 #11 by Paul Francis
Replied by Paul Francis on topic What is this Aircraft?
Yes its the Ministry of Supply Brigand from Boscombe Down used for the dropping trials of the Valiant RATO application, using a ballasted super sprite nacelle
This version of the nacelle is the original one with a long pointed nose, that was designed to fit below the fuselage, the pointed nose having a steel button that pressed against a hemispherical socket in the fuselage, subsequent operational RATOs were wing-mounted. This pic was taken 1952 / 53 while the OP was taken in 1955.
I will delete this pic tomorrow AM
The following user(s) said Thank You: PETERTHEEATER, ianbache
26 Nov 2016 00:20 #12 by Peter Kirk
Replied by Peter Kirk on topic What is this Aircraft?
Well that explains the odd pointy shadow in the original pic. That did confuse me and didn't make it 100% certain it was a Brigand.
Why delete the pic?
26 Nov 2016 09:41 #13 by Paul Francis
Because I don't want it copied.
The following user(s) said Thank You: Peter Kirk
27 Dec 2016 22:42 #14 by Peter Kirk
No photo I'm afraid, only a description of an aircraft that clattered over our house this morning.
Large high wing monoplane with supporting struts.
Single radial engine (sounded meaty!)
Twin finned but fins looked small - couldn't see a central fin as it was too low
Undercarriage was fixed and spindly but not booted.
Colour looked to be dull brown but as it was a bright clear sky it was more like a silhoette.
Nearest airfield is Biggin Hill.
I have heard it before but only seen it in the distance.
Any ideas?
27 Dec 2016 23:30 #15 by WJT
Replied by WJT on topic What is this Aircraft?
Brousard? Its a Froggy jobbie and I think there is one down your way.
28 Dec 2016 09:39 #16 by Peter Kirk
That's the one, thank you. I searched Google with many different search terms but it seems to ignore most of the criteria and pick the easy ones!
28 Dec 2016 09:41 #17 by PETERTHEEATER
Replied by PETERTHEEATER on topic What is this Aircraft?
'Froggy jobby' Surely you mean a masterpiece of Gallic engineering with super strong landing gear....Whoops....!
www.baaa-acro.com/1988/archives/crash-of...ard-in-manchester-uk
Time to create page: 0.039 seconds
