LIDAR
06 Jan 2016 17:01 - 06 Jan 2016 17:03 #1 by netcompsys
LIDAR was created by netcompsys
I know that LIDAR has been mentioned here before but wanted to makepeople aware that there was a zoomable UK map available
A bit about LIDAR here
historicengland.org.uk/research/approach...emote-sensing/lidar/
The map is not of 100% of the UK presumably because most of the work is funded by the Environment Agency so it concentrates on rivers and coastlines, for the assessment of flooding and errosion.
So I have been able to look at the range arrows at Donna Nook, the Lightning at Skegness Park, former RAF North Coates (where there is not even a glimmer of the former Bloodhound site), the Bloodhound site at Bawdsey, where all the concrete and earthworks show up well. Other sites like St Mawgan, Chivenor and Hartland Point are also visible.
Certainly the quality is sufficient to identify earthworks such as fighter pens
Here you go
houseprices.io/lab/lidar/map
Kevin
The following user(s) said Thank You: WILLIAMARNOLD
06 Jan 2016 17:30 #2 by deprecated
Replied by deprecated on topic LIDAR
If you access the data via the governments own portal there are other LIDAR datasets available. The coverage varies and is being added to with time.
If you select a dataset from here
data.gov.uk/publisher/environment-agency
then click on the 'preview on map button you'll get the full list of datasets as map layers and you can select any or all for display.
06 Jan 2016 17:51 #3 by Peter Kirk
Replied by Peter Kirk on topic LIDAR
I think this is a very useful tool but the definition is not yet good enough, for free, to spot the things I am looking for. The best bit is looking at woodland but sadly hidden concrete arrows don't show up as there is no height difference. Still recent forest clearance has revealed two in the last 6 years :)
19 Aug 2018 12:12 - 19 Aug 2018 12:13 #4 by netcompsys
Replied by netcompsys on topic LIDAR
I continue to make occasional use of this tool
house prices .io
Lab
houseprices.io experimental area
LIDAR data
The Environment Agency have just released their LIDAR (Light Detection and Ranging) data under an Open Government Licence.
The composite data covers over 72% of England (no Wales, Scotland or Northern Ireland yet as this data's held by the devolved agencies). Resolutions available are 25cm, 50cm, 1m, and 2m, but coveraage appears very limited at the higher resolutions. The 1m data appears to strike a good balance of coverage and detail, so have mostly been looking at that.
Have grabbed some of the DSM 1 meter data and drawn some map tiles with contour shading shading to produce a zoomable map.
Particularly useful as it accepts OS Grid References as well as names
The images are free to use under Creative Commons Attribution 4.0 International Public License
creativecommons.org/licenses/by/4.0/legalcode
The following user(s) said Thank You: kebecker, WILLIAMARNOLD
19 Aug 2018 12:40 - 19 Aug 2018 12:41 #5 by netcompsys
So this is the former Humberston CHL site before demolition
houseprices.io/lab/lidar/map?ref=TA3277005457
And in the centre of this is the remains of the jetty at former RNAS Killingholme
30 Nov 2019 15:46 #6 by netcompsys
This site gives a split screen view of a location where the top half is Google maps satellite and the lower is the LIDAR map
Note that these are adjacent areas North and South of a centre, unlike for instance wheresthepath
www.lidarfinder.com/
LIDAR is generally only available in coastal areas and those area at risk of flooding
Here is an example which cuts through Donna Nook s Ops Block
30 Nov 2019 17:13 #7 by Peter Kirk
Brilliant. Much easier to find the correct location.
The NLS mapsite also has LIDAR for use as background maps but it only works in one type of map search and I can't recall what it was.
30 Nov 2019 19:52 #8 by mbriscoe
Replied by mbriscoe on topic LIDAR
I saw the Scottish LIDAR mentioned somewhere, I think this is the site.
remotesensingdata.gov.scot/
