AIR 10/4038 - In Print
30 Oct 2009 13:12 #1 by Peter Kirk
AIR 10/4038 - In Print was created by Peter Kirk
I mentioned this in one of my posts under the National Archive.
The TNA bookshop had copies of Air 10/4038 (or it maybe the later one) in printed form nicely bound. It was in two volumes A-K and L-Z.
For those note familiar with this document it records airfield data on one page and include a location map and an aerial photo or layout plan on the other.
The volumes on sale have two drawbacks
  • Each volume is £110.00
  • The reproduction is poor and TNA scans are much better quality (depending on original of course)
Before you knock the price too much I noticed that other volumes of reprinted archive documents carried similar price tags and I suspect the print runs are very limited and probably not even breakeven on margin.
Probably worth considering as a reference book for an aviation library or similar.
02 Nov 2009 16:30 #2 by OneEighthBit
Replied by OneEighthBit on topic AIR 10/4038 - In Print
Wow that is a lot if the reproduction isn't that great :(
You could photograph and reproduce it in almost print quality if you had an afternoon with the originals at the PRO for not very much.
02 Nov 2009 22:23 #3 by carnaby
Replied by carnaby on topic AIR 10/4038 - In Print
Having done just that (almost) - it took a day to photograph, then probably two days to crop / turn / adjust the photographs).
Advantage is I don't need to print anything - if I had to print the lot (1,000 sheets) it would get expensive as there is a lot of grey-scale.
Peter mentions 'it's AIR10/4038 - or maybe the later one'. This is important as AIR10/4039 is roughly three times the size.
02 Nov 2009 22:41 #4 by Peter Kirk
Replied by Peter Kirk on topic AIR 10/4038 - In Print
I'd feinted at the price so didn't take note of the date or original document. Although one data sheet did state "as at ??/??/1942.
4039 is three times the size? I'll have to take extra batteries and memory cards!
03 Nov 2009 19:15 #5 by OneEighthBit
Well you don't have to print it - just make a PDF of it and sell it as an eBook :)
