Forum
Open Forum
Miscellaneous Research Topics
Research Material, Websites and Useful Links
Google Earth thread!
Less
More
Thank you received: 18
12 Oct 2010 10:20 #121
by mawganmad
Thanks Hal, I've just tried this and it worked,
'I went in to control panel- programs and uninstalled Google earth from there. Then found the download I had done (by searching downloads) and reinstalled it.'
Less
More
12 Oct 2010 10:24 #122
by mawganmad
See London is covered now, again it appears to be later tyhan '45, take a look at Heathrow which would suggest very early '50s. Hawkers Langley airfield appears just to the north west of it aswel, fascinating stuff though.
Does anyone know if you can select to view GE without any of the overlaying icons?
Less
More
Thank you received: 0
12 Oct 2010 10:25 #123
by Hal_Chase
Excellent, glad to have helped
The key with most of these '
Google Earth Traumas ' is to totally uninstall first, then re-install with the latest version (5.2).
The 64-Bit thing is an additional issue that some people encounter!
REF
Topic Author
Offline
Platinum Member
Less
More
Thank you received: 652
12 Oct 2010 10:55 #124
by REF
if you uninstall GE does it not delete your saved places?
Less
More
12 Oct 2010 11:13 #125
by Hal_Chase
They should be backed up before you uninstall
On Windows XP they are in C:Documents and SettingsApplication DataGoogleGoogleEarth
On Windows 7 they are in C:UsersusernameAppDataLocalLowGoogleGoogleEarth
If you are on a corporate network and have Windows 7 they will be in C:UsersusernameAppDataRoamingGoogleGoogleEarth
Copy them someplace safe (away from Google folders!!), uninstall GE, re-install GE, then copy them back where you found them.
Less
More
Thank you received: 163
12 Oct 2010 11:16 #126
by Chris Lowe
I've updated GE on 3 Pc's now and not had a problem with any of them.
REF
Topic Author
Offline
Platinum Member
Less
More
Less
More
12 Oct 2010 11:22 #128
by Chris Lowe
Although Harrington area is covered there isn't any sign of it at all.
Less
More
Thank you received: 2
12 Oct 2010 11:43 #129
by TommyUSA
All you really need to save is myplaces.kml - that is the file with the custom 'pins' you've put down. One caveat: if you move the file, the name of the computer should be the same because it is throughout the myplaces.kml file. Or you can use a text editor to change it to the appropriate value. That's what I do anyway...
T
Less
More
12 Oct 2010 13:11 #130
by mawganmad
Here's a list of airfields that are clearly visible in the 1940s images, this was after an hour or so looking about.
Anyone fancy adding to the list?
Bentwaters
Brooklands
Calveley
Cardiff
Conington
Cowes SARO slipways
Croughton
Croydon
Depden
Elstree
Eye
Flixton
Great Ashfield
Great Staughton
Halesworth
Heathrow
Hendon
Heston
Hooton Park
Horham
Kimbolton
Knettishall
Lakenheath under const
Langley
Leiston
Mendlesham edge of
Metfield
Mildenhall
Molesworth
Oakington
Pengham Moor
Pershore
Poulton
Rattlesden edge of, under const
Ringway edge of
Rougham under const
Sealand
Shepards Grove
Silverstone
Snitterfield
Speke edge of
Stradishall
Stretton
Tuddenham
Warboys
Waterbeach
Wattisham
Wisley
Wratting Common
Wyton
I was staggered to find two Long Marstons, but I think the one that you can see is called Cheddington?
Forum
Open Forum
Time to create page: 0.055 seconds
