I have just placed this picture of Honeybourne onto my website of the Airman's Dining Room for 1300 men, designed in temporary brick but built in clay blocks
Splendid Denis and Richard. That's all the proof I need especially since the 'proof' fits my image of what a Terra Cotta Block would look like.
From your pics there is no evidence that the surface was originally cement rendered. If that was the norm for buildings constructed in TCB (Terra Cotta Block) then remaining structures should be easy to identify.
Your mission now, should you choose to accept it, is to track down other examples. I suspect that TCBs were used because it would be quicker to build a temporary structure and because they were available from very local sources so they might only be seen on certain airfields.
Denis's image - The building has a concrete frame, no piers. Richard's image has the piers to support the roof trusses.
If I may point out a slight error in the above. The MOWP Standard Hut to which you refer was designed in 1942 and sponsored by the Ministry of Works and Planning department (hense MOWP) within the Ministry of Works, in association with companies that would benefit from the wall cladding. The system therefore had the advantage over many other designs that wall infilling (or cladding) could be anything available locally but generally was either of the following:
brick
4in hollow clay blocks
plasterboard
Seco
The frames are R/C at 6ft centres (each frame made up of four units bolted together and connected together along the ridge by lengths of gas pipe). There were two standard widths either 18ft 6in or 24ft clear. More details are in my book.
