Gloster Javelin
17 Sep 2014 19:20 #1 by superplum
Gloster Javelin was created by superplum
17 Sep 2014 20:20 #2 by David Thompson
Replied by David Thompson on topic Gloster Javelin
Post #1 on our Gate Guards thread way back in 2008 ;
/community/showthread.php?865-Gate-Guards&highlight=gate+guards
I will be very sorry to see the Javelin go as I well remember her when she stood outside the officers mess back in the early 1970's , and we had a Meteor NF14 on the gate as well . Those were the days !
18 Sep 2014 06:48 #3 by PETERTHEEATER
Replied by PETERTHEEATER on topic Gloster Javelin
The only practical ADEN gun installation in a British aircraft but I never worked them long enough to find out the stoppage rate.
19 Sep 2014 21:23 #4 by YellowPinkie
Replied by YellowPinkie on topic Gloster Javelin
VTTS need a new project...
20 Sep 2014 08:37 #5 by Peter Kirk
Replied by Peter Kirk on topic Gloster Javelin
Not sure if they did the airshow circuit but my first airshow was September 1968 so just a little too late I suspect. Be good to see one as a ground runner but I suspect the engine parts are going to be hard to come by. Another aircraft from the books of my youth.
22 Apr 2015 11:42 #6 by Gone
Replied by Gone on topic Gloster Javelin
I was under the impression that the Hunter Gun Pack was the best ADEN installation?
A former armourer I used to work with maintained that in the Javelin guns, if it fired during a turn would speed up on one side and slow or stop on the other due to the g loads on the belts.
22 Apr 2015 14:44 #7 by PETERTHEEATER
Note that I said 'practical' meaning from an installation and maintenance point of view. The guns were right way up and the ammo feeds were straight and level out of the box, big access panels. The front mounting caused problems with forgetful plumbers who left components in the blast tubes ........
Yes, 'g' forces on ammo feeds can cause belt drag but rarely overfeed due to ducted feedways.
The single seat Hunter installation was operationally the best but off-aircraft maintenance of the gunpack was time consuming and required a lot of space for gun shop and pack storage, hence the Central Armoury configuration.
29 Apr 2015 14:47 #8 by Gone
Thanks, should have realised that that was what you meant.
Did the bits left in the blast tube include the trunnion nut?
Sadly the only installation I've seen for real was the Harrier which was probably the worst with what it did with the belt.
05 Sep 2019 19:26 #9 by REF
Replied by REF on topic Gloster Javelin
Javelin at Flixton
The following user(s) said Thank You: Peter Kirk
06 Sep 2019 08:39 #10 by Peter Kirk
The plan view looks good, shame about the faded roundels though. I always liked the look of the Javelin, no idea why, maybe because it was one aircraft I saw regularly at Manston in the late sixties or early seventies?
Time to create page: 0.059 seconds
