Airspeed Horsa
04 Feb 2016 11:11 - 22 Jul 2017 10:54 #11 by daveg4otu
Replied by daveg4otu on topic Airspeed Horsa
Some of them finished up on the edge of the airfield at Arnehem ....seen here whist on a holiday late 70s...
www.hampshireairfields.co.uk/
04 Feb 2016 15:45 #12 by kebecker
Replied by kebecker on topic Airspeed Horsa
The airfield is nicely censored on Google !
04 Feb 2016 15:57 #13 by daveg4otu
Try Bing Bird's eye - I think it is not pixelated there,
08 Feb 2016 19:36 - 08 Feb 2016 19:38 #14 by netcompsys
Replied by netcompsys on topic Airspeed Horsa
On a visit to Salisbury Hall last year, May 2015
The Museum’s exhibit, acquired in 1975, is a hybrid consisting of the cockpit of a Mk.II Horsa and the forward fuselage of a Mk.I Horsa. The fuselage shows the port side ramp/door, the interior plywood bench seating for the troops along the sides, a folding bicycle for use after landing, the extra section of ramp needed to fill the doorway, and the main skid. Also on view are Horsa wheels, and compressed air cylinders for the flaps.
www.dehavillandmuseum.co.uk/aircraft/air...-51-58-horsa-glider/
10 Aug 2018 07:39 #15 by Gone
Replied by Gone on topic Airspeed Horsa
de Havilland used a Horsa fitted with a replica of the Comet nose. It was towed by a Halifax to test the Pilot's visibility and the effect of rain on the windscreen.
10 Aug 2018 20:51 #16 by PJH
Replied by PJH on topic Airspeed Horsa
Plus, the Sud Caravelle used the nose of the Comet, under license from DH. Therefore you could have a pub quiz question of naming the only glider on which the nose sections of two different airliners were tested - quite a claim to fame!
05 May 2019 15:12 #17 by netcompsys
At the Pegasus Memorial at Pegasus Bridge they have this full size replica Horsa
and a model hanging from the roof
Also on site, but under a narrow shelter and only visible from outside through glass/perspex is a large section of an original Horsa fuselage donated bty the Museum of Army Flying
The following user(s) said Thank You: PETERTHEEATER, canberra
05 May 2019 15:17 #18 by netcompsys
I had not realised before that Horsa's had underwing bays for containers similar to parachure containers for additional equipment
11 May 2019 20:59 #19 by AlastairMellor1
Replied by AlastairMellor1 on topic Airspeed Horsa
It is not all that well known that the Horsa (along with the Hotspur and Hengist) had the requirement to drop parachutists written into their specification. The Horsa's container bomb cells were positioned such that to allow the inner containers to be dropped the main undercarriage had to be dropped first - the main reason the Horsa had a landing skid.
The attached figure is from the AFEE report of the parachuting trials conducted from the Horsa showing a full load of 20 paratroops with kit bags. Strict despatch sequence was required as exit was simultaneously from both the front and rear doors to maintain the cg. Probably the reason why paratroop operations were never carried out from the Horsa.
The Horsa also had trials conducted with the dropping of a full load of supply panniers from the cabin, to achieve this a two track roller conveyor (as wooden as the aircraft itself) was devised, mechanically linked to maintain the sequence and cg. It is possible that these supply drop trials from the Horsa were the first ever use of an aircraft mounted roller conveyor to drop stores, a method which is almost universal today as the Horsa trials pre-date the use of a similar roller conveyor installation (metal) in the Dakota.
The following user(s) said Thank You: REF, netcompsys
17 Jul 2021 12:52 #20 by STAN11
Replied by STAN11 on topic Airspeed Horsa
Most, but probably not all will know that the Shawbury Horsa ended up going to the Netherlands. It now resides in the large Overloon museum.
Time to create page: 0.064 seconds
