Canadair CP-107 Argus
20 Aug 2019 22:08 #1 by kebecker
Canadair CP-107 Argus was created by kebecker
A rare poor shot I took a few years back of 10717 – at the Greenwood Military Aviation Museum in Greenwood, Nova Scotia
21 Aug 2019 10:29 #2 by canberra
Replied by canberra on topic Canadair CP-107 Argus
A derivative of the Britannia.
21 Aug 2019 12:30 #3 by John Anderson
Replied by John Anderson on topic Canadair CP-107 Argus
Among the changes they opted for piston engines instead of turboprops.
21 Aug 2019 12:41 #4 by kebecker
Replied by kebecker on topic Canadair CP-107 Argus
It was also unpressurized which saved weight and improved the endurance.
The following user(s) said Thank You: John Anderson
22 Aug 2019 06:06 #5 by PETERTHEEATER
Replied by PETERTHEEATER on topic Canadair CP-107 Argus
I should have thought that being restricted to a cruising altitude of around 10,000 feet(for passengers to breathe) would have caused a higher fuel burn with less endurance.
22 Aug 2019 07:05 #6 by kebecker
I should read the descriptions a little more carefully! According to the Greenwood museum it was the use of piston engines that really made a difference to endurance. www.gmam.ca/argus--cp-107-.html
The Canada Aviation and Space Museum has a similar narrative
ingeniumcanada.org/aviation/collection-r...canadair-argus-2.php
23 Aug 2019 05:46 #7 by PETERTHEEATER
Thanks. I've got Britannia on the brain.
Being military the individual crew members would have oxygen available and could go to the maximum service altitude. That it would do more-miles-per-gallon on 100 octane gasoline fed piston engines than AVTUR fed turboprops is intriguing. Clearly fuel costs were not a concern.
23 Aug 2019 08:13 #8 by John Anderson
Would need speed to get to the patrol area, but once there would loiter at low altitude. Piston engines more efficient at low altitude?
23 Aug 2019 08:25 #9 by Peter Kirk
Replied by Peter Kirk on topic Canadair CP-107 Argus
I seem to recall something about the Nimrod loitering on two engines, if true, could the Argus do the same or would restarting be a problem and could this also be easier with a piston engine?
23 Aug 2019 09:13 - 23 Aug 2019 09:14 #10 by John Anderson
Any ex Argus aircrew out there?
